Here's a table you can use for home Level 1 (120V) and Level 2 (240V) charging. It covers all common L1/L2 charging scenarios as defined by the J1772 standard. The 8/10/12 hour columns assume a 10% charging loss due to heat and are there to handle the different peak hour exclusions. Also, the Equinox data is based on what I could find and derive from those findings. I put this together before I found out GM is anticipating the ability to charge to 100% with no battery degradation.
The bold row is the standard AC on-board charger acceptance rate for reference. The numbers in (parenthesis) in the 8/10/12 hour columns are range estimates based on the KW number in the cell. Many of these range estimates are longer than the published range estimates, but are included for completeness.
Voltage | Amperage | Max Draw (amps) | Power (KW) | 8 Hour KW (miles) | 10 Hour KW (miles) | 12 Hour KW (miles) | Vehicle | Equinox 1LT | Equinox 2LT | |||
Battery Size (KWh) | 76 | 91.48 | ||||||||||
EPA range | 250 | 300 | ||||||||||
10 to 85% (KWh) | 57.2 | 68.6 | ||||||||||
Effective Range | 187.5 | 225.0 | ||||||||||
Miles/KWh | 3.3 | 3.3 | ||||||||||
House Circuit | 120 | 15 | 8 | 0.96 | 6.9 (23) | 8.6 (28) | 10.4 (34) | Hours 10-85% | 66.2 | 79.4 | ||
House Circuit | 120 | 15 | 12 | 1.44 | 10.4 (34) | 13.0 (43) | 15.6 (51) | Hours 10-85% | 44.1 | 52.9 | ||
EV Circuit | 240 | 15 | 12 | 2.88 | 20.7 (68) | 25.9 (85) | 31.1 (102) | Hours 10-85% | 22.1 | 26.5 | ||
EV Circuit | 240 | 20 | 16 | 3.84 | 27.6 (91) | 34.6 (113) | 41.5 (136) | Hours 10-85% | 16.5 | 19.9 | ||
EV Circuit | 240 | 30 | 24 | 5.76 | 41.5 (136) | 51.8 (170) | 62.2 (204) | Hours 10-85% | 11.0 | 13.2 | ||
EV Circuit | 240 | 40 | 32 | 7.68 | 55.3 (181) | 69.1 (227) | 82.9 (272) | Hours 10-85% | 8.3 | 9.9 | ||
EV Circuit | 240 | 50 | 40 | 9.60 | 69.1 (227) | 86.4 (283) | 103.7 (340) | Hours 10-85% | 6.6 | 7.9 | ||
EV Circuit | 240 | 60 | 48 | 11.52 | 82.9 (272) | 103.7 (340) | 124.4 (408) | Hours 10-85% | 5.5 | 6.6 | ||
EV Circuit | 240 | 70 | 56 | 13.44 | 96.8 (317) | 121.0 (397) | 145.2 (476) | Hours 10-85% | 4.7 | 5.7 | ||
EV Circuit | 240 | 80 | 64 | 15.36 | 110.6 (363) | 138.2 (453) | 165.9 (544) | Hours 10-85% | 4.1 | 5.0 | ||
EV Circuit | 240 | 90 | 72 | 17.28 | 124.4 (408) | 155.5 (510) | 186.6 (612) | Hours 10-85% | 3.7 | 4.4 | ||
EV Circuit | 240 | 100 | 80 | 19.20 | 138.2 (453) | 172.8 (567) | 207.4 (680) | Hours 10-85% | 3.3 | 4.0 |
