1 - 1 of 1 Posts
Any guesses/insights on the specs of the base Equinox EV?
My guess:
• $33,999
• 82-84 kWh battery (10 modules)
• 280-320 miles EPA range
• 190kw DC fast charging
• Heat Pump (confirmed that all Ultiums will have heat pumps?)
Kinda curious about the motor setup. Doubting RWD, because the smallest Ultium main RWD motor appears to be the 255kw (341 HP) used in the base LYRIQ.
Almost seems more likely it’ll use the smaller 180kw (241 HP) permanent magnet front motor unit, then AWD models (it better have an AWD option!!) will get the 62kw (83HP) induction assist motor on the rear axle.
1 - 1 of 1 Posts
