And with likely w/ price + feature combos much better than “ normal“ for its class and a significant upgrade from the Bolt/EUV for close to the same price.These numbers put the Equinox EV at 3.2 to 3.3 miles per KWh of battery, which is right about normal for a vehicle this size.
Likewise - this eliminates the RS and 3LT trims.I will stick to 19-inch wheels to take advance of the capability regardless of which trim I'm able to afford w/ the larger battery back.
I'm wondering if you can swap that out for smaller ones.Likewise - this eliminates the RS and 3LT trims.
I am absolute sure that you can at your own expense. And MAYBE a dealer might swing a swap if he just had someone who had to "go think about it" because 21" wheels cost too much as an option. But usually standard's standard and you can't opt out.I'm wondering if you can swap that out for smaller ones.
I think you'd need to swap them out post sale. After verifying with the dealer that the car's odometer/speedometer can be recalibrated, buy the 19" wheels and tires, sell the 21". I wonder about the economics when all is said and done. You'll be paying full price for the 19" and getting less than that (?) on the 21".But usually standard's standard and you can't opt out.
But then fare cheaper replacements (and easier to replace) once tires wear out. If you have to replace a few times...and you're saving several hundred dollars, it may even out or you may save over the long run...as long as you're OK with budgeting out a little further.I think you'd need to swap them out post sale. After verifying with the dealer that the car's odometer/speedometer can be recalibrated, buy the 19" wheels and tires, sell the 21". I wonder about the economics when all is said and done. You'll be paying full price for the 19" and getting less than that (?) on the 21".
My biggest concern is the load rating for the tires for the 19" rims. The 20" and 21" wheels come on the versions with the 10 module battery pack. It could be the smaller/stiffer sidewall is necessary for the extra weight. But EV specific tires are already addressing this issue.But then fare cheaper replacements (and easier to replace) once tires wear out. If you have to replace a few times...and you're saving several hundred dollars, it may even out or you may save over the long run...as long as you're OK with budgeting out a little further.
You can't even get the Goodyear Electrodrive tires in this size. I have them on my Volt and really like them.My biggest concern is the load rating for the tires for the 19" rims. The 20" and 21" wheels come on the versions with the 10 module battery pack. It could be the smaller/stiffer sidewall is necessary for the extra weight. But EV specific tires are already addressing this issue.
I wouldn't bother with the odometer, even. The circumference of the wheels is differs by a tenth of an inch*, 0.15%, and SAE rules say that odometer readings need to be within 4% of actual. (There's no ACTUAL law about how inaccurate an odometer can be as far as I can tell, only requirements to disclose what it says and wether that figure can be relied upon or not.)I think you'd need to swap them out post sale. After verifying with the dealer that the car's odometer/speedometer can be recalibrated, buy the 19" wheels and tires, sell the 21". I wonder about the economics when all is said and done. You'll be paying full price for the 19" and getting less than that (?) on the 21".
