Chevy may provide a 240V install with the sale like they are doing with the Bolt EUV. Generally about $1500. A 240V station will be in the $500 to $800 range depending on features, Amps. I have a Siemens, but check out Clipper Creek.
I power mine from the electric dryer electrical box. I added a second box for the dryer outlet and put in a DTDP 240V switch where the outlet used to be and ran conduit to the charge station. I use the switch to direct the current to one or the other. Like a HD light switch but for 240V. Up powers the charge station, down powers the dryer. It prevents the two appliances from pulling power at the same time (bad, bad juju). The switch was around $70 as I recall.
It's also important to follow the charge station manufacturers guide on breaker size and wire guage. You do not want undersized wire feeding a hungry car. Smoke, fire, bad stuff. Most dryer use 30A and 10 AWG wire which is fine provided the charge station is sized accordingly.
