For most use-case scenarios, there's little reason to charge to 100% for daily driving anyway. Example, my wife mainly uses our ID.4 - VW recommended keeping between 20-80% when possible for daily use. Her commute is 40 miles round trip. Even in winter, when we've been averaging 2.9 mi/kWh that's about 223 miles total (compared to 255 EPA estimate for my year/trim). If keeping between 20-80% for daily use, that's keeping within 60% of the battery and in these temps would be about 134 miles between charges. So, if not plugging in every day, that's plugging in ever 3 days as the extra range just isn't needed. If you really want to go all out, some recommend certain battery chemistries being best between 40-60% so you could just plug it in every day but tell your car to stop charging at 60% and to start charging when it gets below 40% and if it's not in those parameters plugging in still will help to use energy from the wall to pre-heat/cool the cabin prior to leaving so you can avoid using cabin heating/cooling during the drive to maximize range. For longer trips, as mentioned above, using hopefully shortly after reaching 100%. However, with that said, it really depends on where your first charging spot will be. If your first charger will use 60% of your battery, starting at 100% actually doesn't help you with time, because you'll be drawing energy at a slower rate from DCFC at 40% compared to 20%, so sometimes it's actually beneficial to
not charge to 100% on a longer trip if you want to maximize trip efficiency. Of course, range anxiety is real, so just do what's comfortable, but generally as mentioned above, follow what the manual says. I've seen people say on many forums, "it's your car, do what's best for you" but I think that really only applies if you: a) have a lease and plan on trading up afterwards; b) you purchased but plan selling in the next 5 years when battery degradation isn't significant (dependent on miles driven). However, if you plan on owning the care past the warranty, it may be beneficial to maintain according to manufacturer's suggestions. On that, some have said, "that's what the battery is for" but even lower quality batteries on older Leafs, some people have noted that they didn't qualify for the warranty because by the time they reached the warranty limit, their battery hadn't passed the threshold of degradation to qualify. If it did, though, there's some concern that the manufacturer could look at stats from your car's computer and see that it was DCFC'd exclusively and charged to 100% every time.
Ultimately, some questions:
- Do you need the range every day?
- Does the manufacturer recommend against it?
If the answers are no, then simply setting the car to charge to 80% should be sufficient.
If you do need the range, well, you need the range...just make sure to start driving not too long after hitting 100% (you can set departure times on most EVs for charging, so easy peasy)
