21 - 40 of 51 Posts
There is no charge for nitrogen. The benefit is that you set the number at the station, and it fills the tires while giving a beep sound to indicate when to stop.
I missed the Costco part. I thought the dealer was trying to charge you for it like all the other tire guys. I've never seen it at my local Costco, but I'll keep my eye for it. Thanks for the heads up.
Discussion starter · #27 ·
If I installed OEM TPMS purchased from Chevrolet to install in a set of winter wheels, is programming required or will the vehicle auto-program the TPMS after driving for a while?
You won't need a relearning tool, autoperformance.
Discussion starter · #30 ·
It was supposed to program itself though
...without needing to buy a relearn tool or manually drop air pressure from each tire, then refill them. See #29 above.
Reactions: autoperformance
In our Nox EV, the TPMS reads about 3-4 psi low compared to 4 independent/manual pressure gages. So the "alerts" are not only annoying but if I fill the tires to the pressure required to stop the "alerts" or notifications, then they ride like a rock and I feel every bump/rock on our unpaved roads. The notifications are kinda useless and annoying for me.
How do you reset or clear the low tire pressure alert?
Discussion starter · #32 ·
fyi, My 2010 Accu-Gage tire pressure gauge has always been within 0, -1, or -2 psi of the car's reading whether on the Volt, Bolt or Equinox EV.
I did get the GM tpms sensors from Rock Auto and now have to get a shop to install on my winter tires. Just wondering what is a fair price for this work? I live in Michigan.
I also purchased a scissors jack, which I may need to fix a tire or rotate them. This is the same type and style I have in my ICE Blazer, and it works great with a battery-powered pneumatic gun for very quick work.
When I picked up my car from the dealership, all the tires were at 35 psi. One day, one of the tires dropped to 32 psi, so I refilled it back to 35 psi. The next day, I received an alert on my myChevy app indicating a 'Flat Tire' notification for a different tire, which was at 33 psi and refilled to 37 psi. Today, I checked the 'Tire and Load Information' sticker on the driver’s side door. Do you keep all the tires at 42 psi?
Has anyone ever filled your car tires with nitrogen at the Costco tire inflation station?
Same. I did not check the inflation from the dealer but started getting low-pressure alerts today. Filled them all up with atmospheric air today to quell the chorus of car complaints. the tires (21 inch) are marked 50 psi but that seems high to me, so 42 psi it shall be. 50 psi must be the do-not-exceed value.
To help keep drivers aware of impending flat tires, tires that will prematurely wear because they are too low, or even tires that are too highly pressurized, the Equinox EV comes with a TPMS that can warn drivers or inform them in real time of each tire's pressure.
DIC, App Tire Pressure Display
The tire pressure readings can display in the Drivers Info Center (DIC)—OM p 108 —and also in the myChevroltte app. I like to have the tire display up all the time to catch a leaking tire before the alert goes off but day-to-day to maintain the correct tire pressure: 42 psi (OM p.295). If I see a drop a few psi I top it off. If it happens regularly, there may be a slow leak in the tire bead or even a nail in the tread.
If the tire is overinflated by more than 35 kPa (5 psi), the horn will sound multiple times and the turn signal lamp will continue to flash for several seconds after filling stops. To release and correct the pressure, while the turn signal lamp is still flashing, briefly press the center of the valve stem. When the recommended pressure is reached, the horn sounds once. OM p.298
Sensor Accuracy
In my experience it's not unusual to see a TPMS disagree with a manual gauge by a few psi. Of course then you get into the accuracy of the hand gauge as well. Maybe it's off a few psi.
You can compare the car's reading with a number of tire pressure gauges to see if there's a consensus of some sort. Or, you adjust and mentally add a few psi to what the TPMS displays. I'd like dead nuts accuracy, but the most important function is to alert on a big pressure drop indicating a severe puncture.
TPMS Sensor Matching Process — Auto Learn Function
Each TPMS sensor has a unique identification code. The identification code needs to be matched to a new tire/wheel position after rotating the tires or replacing one or more of the TPMS sensors. When a tire is installed, the vehicle must be stationary for about 20 minutes before the system recalculates. The following relearn process takes up to 10 minutes, driving at a minimum speed of 20 km/h (12 mph). A dash (-) or pressure value will display in the DIC. See Driver Information Center (DIC) > 108. A warning message displays in the DIC if a problem occurs during the relearn process. OM p.298
TPMS Sensor Matching Process — Manual Learn Function
  • Each sensor has an internal low frequency coil. When a TPMS "relearn" tool is used in activate mode, it produces a low frequency transmission that activates the sensor. The sensor responds to a low frequency activation by transmitting in learn mode. When the TPMS antenna (in the box on the windshield) receives a learn mode transmission while in TPMS learn mode, it will assign that sensor’s ID number to the location on the vehicle relative to the order in which it was learned. A relearn tool need that supports 433MHz (I think). To place your Equinox in relearn mode use the steering wheel controls to display Options > Tire Pressure > Relearn (I think).
  • When rotating tires, make sure the new tire locations are known by the car. The relearn tool does this and the whole process takes under a minute. OM p.298
  • Aim at the sidewall below the valve stem, and not at the stem.
  • 'If you can not get a sensor to initialize, try pushing the vehicle forward a foot or two. The signals can be blocked by components like rotors, calipers and knuckles. By repositioning the sensor, it may unblock the sensor. This is far more common on the front wheels.
  • TIP: In order to prevent possible electrostatic discharge damage to the TPM Sensor, technicians should be statically discharged before checking or filling tires.
Other Tidbits
In googling I found this about GM's TMPS sensors:
  • Sensors have a 10 year /150,000 mile (240,000 km) battery life.
  • Each sensor takes a pressure measurement sample once every 30 seconds while in stationary mode. If the tire pressure increases or decreases by more than 1.2 psi from the last pressure measurement, another measurement will occur immediately to verify the change in pressure. If a pressure change has indeed occurred, the sensor transmits in Learn mode.
70% Trigger For Warning Light
When a tire’s pressure drops from to 70% of the recommended cold inflation pressure (listed on the vehicle placard on the driver’s door opening, not the tire sidewall), the TPM warning light will illuminate to warn the driver of a low tire pressure condition.
OM p.99:
This light comes on briefly when the vehicle is started. It provides information about tire pressures and the TPMS.
Solid vs. Flahsing Warning Light
When the Light Is On Steady
This indicates that one or more of the tires are significantly underinflated.
A Driver Information Center (DIC) tire pressure message may also display. Stop as soon as possible, and inflate the tires to the pressure value shown on the Tire and Loading Information label. See Tire Pressure > 293.
When the Light Flashes First and Then Is On Steady
If the light flashes for about a minute and then stays on, there may be a problem with the TPMS. If the problem is not corrected, the light will come on every time the vehicle is started. See Tire Pressure Monitor Operation > 296.
With low tire pressure, the warning light on the instrument cluster will stay on solid and no system DTCs will be set. If the warning light flashes, there will be DTCs set, and there is a TPM system condition that needs diagnosis.
42% of Drivers Don't Know
A 2014 study by Schrader International, a company that manufactures TPMS systems, found that 42 percent of drivers are unable to identify the low tire-pressure warning light on the instrument cluster.
Roughly the same percentage of those polled admitted to rarely checking the tire pressure.
GM TPMS
GM TechLink
Great information. I bought a tool for $12.00. When the sensors first came out, you didn’t need a tool, but deflated the tires slightly string at the drivers side front, passenger front, then rear, then driver rear. GM decided to remove that process a few years later. The tool is so much easier.
JDIAG 2IN1 TPMS Relearn Tool Super EL50448 for GM and for Ford Tire Pressure Monitor Sensor TPMS Reset Tool 2025 Edition
Prime Member Price
$11.39
https://www.equinoxevforum.com/\"ht...49B67/ref=syn_sd_onsite_desktop_0?ie=UTF8&psc=1&pd_rd_plhdr=t&aref=KyRLJkRFDM\"
  • Image
  • Image
I am in process of swapping the 21" wheels/tires that came with my 3RS to more comfortable 18" wheels and tires. I bought used 18" wheels off 2018 Traverse that came with TPMS sensors, but different parts number from the ones used in EQEV.
I learned from other thread that the OEM TPMS sensors found in our EQEV wheels are ACDelco 13556202. And reports are that after market TPMS does not work well with EQEV. I didn't want to try the OEM sensors for Traverse, so bought used 13556202 TPMS sensors to use in the wheels.
I am taking the wheels and sensors to a tire shop this week so have tires installed and mounted on my EQEV. It will be interesting to see how the car behaves after mounting a new wheels. The original wheels will be still sitting inside the car. And new set will be mounted on the car. If the shop follows correct relearn procedure, the car should know the new set of wheels are on the car and old set is laying on the deck.
But there is a good chance, the relearn fails. If that happens then I may have to use my TPMS tool to do the relearn procedure.
If you are using the OEM TPMS sensors, all you do is add air to the tires, Station420. Mine reflect the new values almost immediately. If not, the Infotainment display can be used to initiate a (tool-free) relearn by the car
Apparently, new set of OEM sensors are also not auto-relearned by the car. At least my car did not after swapping the stock 21" wheels/tires to 18" wheels/tires with OEM (parts# 13556202) installed.
After driving with a new set of wheels and sensors, the warning came up and TPMS cold not display the pressure. The relearn pressed DIC reset it but as commented by Station420, it just brings back an old static value. And after driving about 10 miles, the warning comes back.
I had to use my Autel TS508 TPMS tool to go through the position relearn procedure and write ID via OBDII port connection.
21 - 40 of 51 Posts
