So one of my last projects during the holidays was to get back to my lighted bowtie installation. Recall that I made an attempt last fall on a Sunday afternoon and discovered that when Chevy built this car they started with the bowtie and built the entire car around it. Not really, but it was much harder to get to than I originally thought, and I wanted a few days when I didn't need the car before I pulled it apart in case something went wrong.
The entire front fascia DOES need to come off. That is a bitter pill to swallow. What's even worse is I could come up with no documentation that would help me find all the clips, bolts, etc. There doesn't even seem to be illustrations of aftermarket fascia's for the collision market (like on CarID) yet that I could reference to locate the mount points. The document that you CAN find for the bowtie itself basically starts after you have the fascia off and upside down on the bench...no help there. So I resorted to my old tried and true method of removing logical fasteners and then giving the occasional tug to see what moves and what doesn't, then searching in the areas where there was resistance.
This is NOT a project for the faint of heart. You're dealing with a lot of plastic and there are many opportunities to break stuff, permanently deform stuff, or scratch stuff. Depending on your skill level, you might be better off letting the dealer do this job. For reference I am NOT a professional mechanic but I've been working on machinery since I was a kid (about to turn 50), and am a very experienced and well-equipped amateur. If this is you, and you have more nerve than common sense like me, then you can do this, especially taking advantage my experience and what I learned on this one. Best viewed on a PC screen.
First thing...do yourself a favor and give yourself some room to work.
See that? I have way too many projects. I also have two lifts, a 4 post and a 2 post, and I elected to do this job on the ground. The 2 post would probably have given the best access to the car but I had a tractor on it. That's another thing...if you do this job on the ground, you're gonna be getting up and down a LOT. Keep that in mind. Anyway this pic shows BARELY enough room to do this job. No less. Right away there was an issue...how to I jack the car up? Supposed to use the pinch welds on the sides but there's no room in this bay for that. I elected to put rubber pads on 2 floor jacks and lift each front a-arm, then support the pinch welds with jack stands. Once the car is up, get those front wheels off. Holy crow those are heavy wheels and tires!
Before we really get into it, you're going to encounter 2 types of screws. They are both the same thread size (designed to go into those slide on metal clips) and may vary in length here and there, so keep track. One is Torx head screw (use a T15 bit) that has in integral washer. It's used on smooth plastic trim panel type locations that need the load distributed. For example the fiberglass fender liners, smooth plastic of the fascia to splash shield interface, etc. The other is a Hex head screw (use a 7mm socket) that is used on thicker, more structural items like support brackets, the underside splash shield, etc. Make it easy on yourself and keep track of what goes where and you'll save time reassembling. You'll also encounter a plastic push pin here and there, the type that you have to pry the head up on to release.
Start by removing the forward screws and push pin that hold up the fender liners. You'll also have to remove the forward "drip edges" that interface the front of the liner to the splash shield. The liners are fiberglass (I think) and are nicely designed to be folded at the 12 o'clock position, so just fold them back and tuck them behind the spindles. Now they're out of the way.
Admire all the bits and bobs under that shield. At some point, notice the two fascia retaining bolts that need to be removed.
Left side:
Right side (behind the horns):
Also, since you read my whole set of instructions before starting this yourself (you did, right?) you know I recommend disconnecting the forward camera connector from the right side of the fascia (actually visible in the above photo) as well as the large body connector on the left side NOW while the fascia is still mounted. It can be done later, but there's a risk you'll damage the wiring, so do it now. These are the only two electrical connections to the fascia. I remind you of this later on when we get to the point where I did it and realized it could/should have been done sooner.
Remove all the underside fascia to splash shield screws. I believe there were 4 across the center and 4 at each corner.
